We have a 52 plate ford transit minibus. Drove it down to the mot test station with no problems. They went to drive it into the garage and it wouldn't start. It turns over but won't fire. They don't currently have time to look at it - been there a couple of weeks already.
We (well the husband, I observe and try to make helpful suggestions) looked at it over the weekend. We could see a broken wire near the relay box. See photo. Have fixed that but still no joy. Does anyone know what this wire is for?
If he put fuel down the pipe from the air filter then the engine does catch and run for a second or two. The easy start test?
He has a diagnosistic box that we used to remove the delimiter when we got it a couple of years ago, but now we get an error code when we plug it in and it won't detect the van.
The garage assume they will need to replace the fuel pump, but unsure as it was fine until we stopped outside.
Any ideas of what we can try? (it's outside the garage and we have the key)
