2013 Mk7 2.2 tdci egr cooler
Postby cledthehead » Tue Feb 16, 2021 9:05 pm
Hi, My name is Cled and im looking for some advice. Just bought a 2013 2.2tdci which looses all coolant after about 20 miles. The seller was told that it was the
head gasket but im inclined to think its the egr cooler. There is quite a bit of water dripping ot of the exhaust. I also think the coolant system might be pressurised
bu exhaust gasses. If I bypass the egr cooler by conecting the two hoses together would it be safe to drive home about 160 miles so that I can work on it properly
in my garage.
cledthehead
Re: 2013 Mk7 2.2 tdci egr cooler
Postby knobby1 » Wed Feb 17, 2021 12:59 am
Yep, shouldn't be an issue to drive after by-passing the cooler.
Is there steam or white smoke coming from the exhaust..?? Does it smell sweet..??
Check your oil level just to make sure it's not the core plugs leaking.
Postby cledthehead » Wed Feb 17, 2021 4:37 pm
My sense of smell is kaput, white smoke or could be steam & water dripping from exhaust. How dificult is it to join the hoses, any pics?.
cledthehead
Postby knobby1 » Wed Feb 17, 2021 8:27 pm
cledthehead wrote:My sense of smell is kaput, white smoke or could be steam & water dripping from exhaust. How dificult is it to join the hoses, any pics?.
FWD or RWD..??
Either way, just pop the two hoses off the cooler and connect them with a suitable piece of pipe and jubilee clips.
http://www.catcar.info/ford/?lang=en&l= ... MysxMzM%3D
Postby cledthehead » Wed Feb 17, 2021 9:17 pm
Its front wheel drive, My current van is a 2.0di Mk6 so I have no experience of this cooler, Where is it located and is it difficult to change. And thanks very much
for your help.
cledthehead
Postby cledthehead » Wed Feb 17, 2021 10:20 pm
Sorry just spotted your link so now I know where its located.
cledthehead
Postby cledthehead » Sun Feb 21, 2021 4:24 pm
OK Bypassed the cooler and drove home 260km (160 miles) without any problem, Water temp stayed normal all the way but the expansion tank is bubbling like a cauldron. Must still be exhaust gasses entering the cooling system somewhere, any ideas? Thanks Cled.
cledthehead
Postby Stumble » Sun Feb 21, 2021 5:38 pm
Maybe its the water pump or expansion cap even
Stumble
Postby cledthehead » Sun Feb 21, 2021 11:19 pm
Thanks for that, You obviously know your stuff. Any other ideas?. How about Lord Knobrot?
cledthehead
Postby knobby1 » Mon Feb 22, 2021 12:47 am
cledthehead wrote:Thanks for that, You obviously know your stuff. Any other ideas?. How about Lord Knobrot?
Water pump is indeed a possibility....they're driven by the PAS and the spline between them often wears out and fails.
http://www.catcar.info/ford/?lang=en&l= ... EzMw%3D%3D
Postby Stumble » Mon Feb 22, 2021 1:46 am
nurrr
Stumble
Postby cledthehead » Tue Feb 23, 2021 9:40 pm
I wanted to post a video of the expansion tank which looks like a kettle boiling even on tickover but was told that MP4 is not accepted on the forum. Even though it looks like its boiling the temperature stays normal. To me that means there must be exhaust gases entering the cooling system.
cledthehead
Postby jjtom » Sun Feb 19, 2023 11:02 am
Did you ever get to the bottom of this issue
I’ve a 2013 rwd 2.2
Bought it with engine problem, bubbling the water from the bottle, I bypassed the egr cooler with a hose, will idle at 60 degrees for an hour with no interior heating, after holding it at a Rev for a minute or two temp guage rises and interior heat starts, but lose it again once left to idle
jjtom
Postby tranmx2 » Mon Feb 20, 2023 2:22 am
Bubbles in the coolant are due to the head gasket or and head and block damage.
With the coolant level being between min/max it is unlikely that exhaust enters the coolant system via the EGR heat exchanger with the engine stopped, if the exhaust system is partially blocked such as when the DPF becomes sooted up the pressure in the exhaust can reach 50 psi or more at idle, 200 psi or more at 3000 rpm, the coolant pressure is relieved at 21 psi. At idle with a clear exhaust the exhaust pressure is about < 4 psi, at about 3000 rpm the exh' press' is about 42 psi.
Due to there being numerous places where exhaust can be trapped it is likely that the circulation of the coolant is limited/stopped.
Better to start your own post re' this subject.
2012 MK 7 E 5 100-350 3.5 XLWB RWD Duratorq 2.2L CR TC 14 DSL 100/125 PS E5 DPF BCM PCM RCM
Was DRRB 74 KW 100 HP 100 cv. Now CYR5 125 HP. PCM could still be for 100 HP.
There's more letters after a Transit than a military man :lol:
tranmx2
Users browsing this forum: Google Adsense [Bot], simonwood
