andz327 wrote:2008 is mk7 so they are self bleeding ,fill filter with diesel and turn the key
thats been well fooked about with cowboys, turning over and not starting could have been as simple as an ignition switch(£20 genuine ford) but think you may have more than one problem now with that messing about as injectors if not fitted in original positions will need to be reset with computer for a start
You'll need to see what fault codes its showing
Did the cramk sensor get replaced and not just the broken bracket????
ANDZ
andz327 wrote:Did all the learns go through ok ??
ANDZ
ANDZ
ANDZ
Stumble wrote:What about the PRV ?
speedmunky wrote:Stumble wrote:What about the PRV ?
I think the prv is fine ‘cause it holds roughly the desired fuel pressure within about 5% but occasionally it’ll fluctuate to within around 20% for a moment then go back to with 5% of the desired fuel pressure
You said it wasn't getting pressure and could only start easy that could be prv causing thatStumble wrote:What about the PRV ?
andz327 wrote:speedmunky wrote:Stumble wrote:What about the PRV ?
I think the prv is fine ‘cause it holds roughly the desired fuel pressure within about 5% but occasionally it’ll fluctuate to within around 20% for a moment then go back to with 5% of the desired fuel pressureYou said it wasn't getting pressure and could only start easy that could be prv causing thatStumble wrote:What about the PRV ?
ANDZ
andz327 wrote:Going back to your flywheel sensor that you fitted ..... how'd you gap the air gap between sensor and flywheel
ANDZ
Users browsing this forum: Google [Bot], Google Adsense [Bot], Majestic-12 [Bot], metalworker0
