Mk7 Doris wrote:Hi all. I’ve a 115 Mk7. I’d like to install a VNT turbo from a 140 onto my engine. I’ve got 140 injectors and fuel pump ready to install. Do I need the engine loom from a 140 too, or are the connections already on my own loom? Do I also need the ECU from a 140 or can I reprogram mine?
Thanks in advance.
Fuel pump is the same for all three Mk7 2.4's, no need to change unless it's fugged....which is unlikely.
Injectors are indeed different and will need to be coded and learns done after fitting.
As Loot says, some may have the turbo actuator connector on the loom, it may be taped to the main part of the loom...if not you'll obviously need the 140 engine loom. PCM will probably need re-programmed to 140 spec as it won't know the 140 injectors and electronic turbo actuator are there.
