loot wrote:If you pm me a gmail I will send you the wiring diagram.
The brake switch and brake lights and Awd relays and pressure switches all need to work plus it may be disabled if there's a fault with the abs or water ingress into the tow socket if fitted etc. Lots to check but a fairly simple system. Also don't assume a clicking relay works as I have some on my van that click but don't
Rafalinio151 wrote:loot wrote:If you pm me a gmail I will send you the wiring diagram.
Hello, can I ask for the AWD diagram via email? I have a problem with my drive. rafalinio@vp.pl
pavlo88 wrote:loot wrote:If you pm me a gmail I will send you the wiring diagram.
Hello, can I ask for the AWD diagram too? mularczykpawel@gmail.com
Thank you in advance
