by Nighthawk » Sun Oct 14, 2007 9:17 pm
did you find it?
If you have a single battery, slide the drivers seat all the way forward, you'll see a flat black plastic panel with a clip in the corners.
pull the flap up and you'll see the battery.
If you have twin batteries, the cover is different.....slide the seat back and you'll see a black plastic knob in the center of a panel, twist it 90 degrees and remove it. Then slide the cover forwards towards the pedals. slide the seat forwards now and you'll see the batteries.
Transit.........Job done
