STD charging system, only requires split charge VSR. Which can be fitted Infront of your current battery.
For a camper build I'd be tempted to retrofit the twin battery setup which is found STD on the RWD vans, which allows the rear(position your current battery is in) battery purely for starting an the front battery for running your general electrics. Like interior lights, radio, remote central locking, etc. Then fit a split charge VSR and leasure battery to runn all your other camper demands in the rear.
To retrofit the factory twin battery setup is fairly simple, you only need a couple of wires and a relay out a scrap van and activate it in the BCM config.
Sorry if this sounds immediately complicated, it is simpler than it reads.
Sent from my A55ho11 using Crapatalk
2008 350LWB 115PS ex fitters van "retired"
Bikes, yes, a few bikes.
V86+patchV86.04X-ProgC81
