KSQ wrote: ( I don't hear it wirring when I unlock the van ).
<snip>
Any help with bleeding the hydraulics gratefully received, I think cracking a joint and turning on the ignition could be a little dangerous........................ Thanks, KSQ
ossie cossie wrote:mine has now started to do the same as yours, it seems to be running slowley but still runs when the door is opened all be it slowly
spudmab wrote:Our work van had a blown motor, i got a vw abs motor, modified the shaft so it fitted the adapter part and bolted it back in.
We have covered loads of miles and its still spot on, it cost £10.00 for the abs pump motor of ebay. A bit of time with a grinder, dermal and some files and its like new.
They motor can be removed from under the van with out to many issues, it has 2 or 3 torque head bolts and a wiring plug. Didn't have to touch any other the hydraulic system or anything else.
To refit is a bit fiddly but no where near as bad as some jobs.
Sent from my SM-N981B using Tapatalk
It was a VW abs pump motor, i think ours was from a golf but im sure there much of a much.WheelyBigBox wrote:spudmab wrote:Our work van had a blown motor, i got a vw abs motor, modified the shaft so it fitted the adapter part and bolted it back in.
Can you provide the details of the model of pump you took your motor from? - What car did it come from? - Would be very handy to know more details on these hacks as so many others have issues with HPU motors. We need to help each other out!
