Hello,
Day 6 of owning a Mk 7 Transit and I’m working through various electrical issues.
The list so far:
Resolved:
- Air con not working but resolved due to a dirty contacts on the push on/off air con switch.
- Non original internal load area light removed as broken unit. Power supply tested and ok, just need to order some new light fittings.
- Tape removed from where 3rd brake light used to be, fished out wiring from the bottom of the rear door, cut off corroded connector and ordered new OEM brake light. Power is fine when brake pedal pressed.
- One of the number plate lights not working as the unit was cracked and let water in, contacts dirty. Ordered new fitting and cleaned up contacts ready for the new fitting.
- Rear light cluster connections cleaned and put back together, all lights ok.
Still working on:
- Rear parking sensors not working. Did all the usual tests of listening for a click/slight vibration but nothing. Followed the wiring until it disappears into a hole just beneath the o/s rear number. No idea where it goes from there, so more reading and investigation needed. I’m hoping the wiring is accessible to clean the connections and chase the power to identify any faults.
- Remote unlocking not working. So a process of elimination has begun to find the fault. So far, I’ve checked the battery and its 3.1v so thats, fine. I noticed someone had tried to change the battery and not soldered in the negative wire, so I did that. Still no joy. I tested the 3 tiny push switches and they are fine. I then tested to see if it was actually transmitting using a multimeter and diode and its not. Here’s a picture of the readings for a remote from my other car v the blue Ford fob. A simple test, but at least I know I’ve got a dud fob now so hopefully, don’t need to start removing the headlining to find the receiver unit, at least not yet. What’s the best plan to get a working fob?
Cheers, Richard
