P2033 - Exhaust Gas Temperature Sensor
Postby layz » Thu Apr 15, 2021 7:09 pm
Ford Transit 2.2, 140bhp, 2012, FWD
Alright so a week ago this code came up and I stupidly didn't act on it and now there is a problem with the particulate filter.
P246C - Particulate Filter Restriction - Forced Limited Power (Bank 1)
P2463 - Particulate Filter Restriction - Soot Accumulation (Bank 1)
Unrelated but would be lover to fix:
P0673 - Cylinder 3 Glow Plug Circuit / Open
P0674 - Cylinder 4 Glow Plug Circuit / Open
Transit mk7 2012, 2.2 140 FWD DPF
302.000 kilometers
layz
Re: P2033 - Exhaust Gas Temperature Sensor
Postby gt_addict » Thu Apr 15, 2021 7:42 pm
Tried changing the sensor and doing a static regen?
gt_addict
Postby Frag » Thu Apr 15, 2021 7:49 pm
Wiring for temp sensor prone to breaking off flush with the connector plugs on crossmember bracket,as the loom comes down over gearbox on FWD.
Fix the fault,will need a static regen with the codes you have now.
Dynamic (on the road) regens inhibited above 150% soot load.
Frag
Ford Technician
Postby layz » Fri Apr 16, 2021 10:32 am
layz wrote:Ford Transit 2.2, 140bhp, 2012, FWD
Unrelated but would be lovely to fix:
i see i was in a hurry when i posted this, i didnt write the full question...
whats missing is my question about where exactly i find this sensor. i was looking underneath the van and i found a part of the exhaust that has sensors, but those seem to go to the dpf pressure sensor, so i guess i was looking at the dpf. i'll take some pictures to clarify.
302.000 kilometers
layz
Postby layz » Fri Apr 16, 2021 10:35 pm
found it!
302.000 kilometers
layz
Postby layz » Fri Apr 16, 2021 10:46 pm
Frag wrote:Wiring for temp sensor prone to breaking off flush with the connector plugs on crossmember bracket,as the loom comes down over gearbox on FWD.
absolutely right. i will do a regen tomorrow.
302.000 kilometers
layz
Postby layz » Sun Apr 18, 2021 10:12 am
regen started but failed after 63%
i did keep an eye on the soot level and dpf load and the numbers made no sense to me because i dont know how they should behave or what is considered safe.
302.000 kilometers
layz
Postby gt_addict » Sun Apr 18, 2021 11:21 am
layz wrote:regen started but failed after 63%
I got this when my vapouriser failed and my soot level was 200%.
gt_addict
Postby lwcrs2001 » Thu Nov 16, 2023 6:30 pm
Hi did you manage to find out the problem as my van is doing the same.
Cheers
lwcrs2001
Postby tranmx2 » Thu Nov 16, 2023 8:26 pm
The posts are 2021.
Better to start a new post.
Watch O Reiley utube DPF vids.
Some claim that the glow plugs in the cylinders are required for regen' Never seen an explanation as to why.
The DPf regen has its own fuel supply and glow plug - heater - The exhaust gas temp is around 300 c and raised to 600 c by the vaporiser and it's glow plug after the vapouriser and before the DPF.
Starting an engine in cold weather without the using the glow plug would add to soot accumulation.
The differential pressure of the DPF is used to start a regen.
Better to watch several of O Reiley's vids to get the idea.
2012 MK 7 E 5 100-350 3.5 XLWB RWD Duratorq 2.2L CR TC 14 DSL 100/125 PS E5 DPF BCM PCM RCM
Was DRRB 74 KW 100 HP 100 cv. Now CYR5 125 HP. PCM could still be for 100 HP.
There's more letters after a Transit than a military man :lol:
tranmx2
Postby lwcrs2001 » Sun Nov 19, 2023 4:37 pm
Cheers for reply. I have been watching him on youtube, very intelligent guy, but i am no mechanic so i only get the basic of it. I have checked the wires underneath and all look ok. I have just replaced my vaporizer as is was blocked up. I not sure if i need to do anything after installation or just do a regeneration, as fault codes still there.
lwcrs2001
Users browsing this forum: Google Adsense [Bot], shaun1963
