biggreentipper wrote:Yes a mk7, PRV wasn’t done . Learns?
Thanks for the reply
Normally when the SCV is changed, the PRV is also changed....If the SCV is faulty it can overpressurize the system and take the PRV with it.
If the learns weren't done it will never run properly. If any part of the fuel system is repaired or replaced, the learns should be done to re-calibrate everything back to datum.
Check the PRV isn't blown, it's a common cause of frequent stalling.
