Can someone point me in the right direction of to where to locate this fault?
P0673 - Cylinder 3 Glow Plug Circuit / Open
P0674 - Cylinder 4 Glow Plug Circuit / Open
Ford Transit 2012, 2.2 FWD
Cheers
walt1984 wrote:It will be the glow plugs them self's that have failed.
Best to change all 4 because you need to remove the inlet manifold and EGR valve to get to the plugs.
Sent from my SM-A107F using Tapatalk
walt1984 wrote:2012 will be a euro 5.
The glow plugs arnt wired together like older diesels but are wired individually and run at a differnt voltage (4.4 volt I think)
Still need to remove inlet manifold.
I took egr off to clean it at same time.
Mine ran for years with no4 not working.
Then 3 and 2 failed last winter.
gt_addict wrote:All four of my glowplugs were open circuit until recently. Still started and ran fine. Fords wanted £350 to change all four.
layz wrote:gt_addict wrote:All four of my glowplugs were open circuit until recently. Still started and ran fine. Fords wanted £350 to change all four.
It sounds steep to me but what do I know.
Is it a reasonable price?
