Hi we have a Mk6 350E RWD 2.4 chassis cab with a fault related to the EGR control, I have code read it and came up with P0404, P0403 and B1600. i cleared all but P0403 which is to do with the EGR valve control. Just to make sure i removed the EGR valve which wasnt too dirty and gave it a good clean out making sure the valve opened and closed under screwdriver pressure, refitted it , tried to clear the P0403 code and it wont clear, its still showing even without starting the engine which makes me think it could be a fault with the vacuum solenoid valve. Now my problem is i think this valve is supposed to be bolted to the rear of the radiator cowling on the passenger side and it isnt, the only valve there has a 8mm pipe running across to the air filter. Is this correct and does anyone else have any idea?
Thanks in advance, Brian.
