Mills wrote:Hi still having troubles. Was getting the P068A code constantly and occasionally the mass airflow sensor code, decided to checkout fuses, wiring etc. Anyway cutting a long story short decided to see if anything was coming out of PRV so removed the pipe and blanked it with a drill bit, started van and it was like a diesel tap! I assume this means the PRV is blown. But before I replace it I wanted to now. Should I try SCV first? Would this be the reason I cannot seem to get the air out of the fuel system or could the air cause this. Any information will be greatly Received.
phil drew wrote:Have you changed filter housing
Mills wrote:Hi
From memory each bottle had around 35-40ml in all looked even.
Thanks for replying
