Hi guys
It's a 2.4 RWD and i've got oil slowly dripping from it. It's dripping off a boit but it's coming down the outside of the metal casing that the bolt is in - I'm just wondering if anyone else has experienced this and what the cure is?
I can't work out if it's the sump seal which is shot (please no, the nuts / bolts look rusty..) or what appears to be some sensor that's plugged in?
Here's a pic of the bolt it's dripping from (just before i took the pic i wiped off the oil from the bolt):
Many thanks for your help!
WBB
