Hi all. Removing the gearbox to do the clutch on 2011 2.4l diesel 113/350.
Bit of a nightmare job as 'salted road use' hasn't done me any favours.
There are two forward facing bolts holding the box in place under the exhaust.
The upper of these two bolts is waaaaaaay tight, seized but also very difficult to access.
Got a power bar & socket on it, but not enough room to move the bar
Any tips on how best this bolt is removed.
Socket or spanner? From under or front (through engine bay) with extensions and universal joint?
