Scooby doo wrote:Why is it when you go into dtc it says successful reading, no error codes found, but previous page shows otherwise?
This is done with ignition on engine off, does we need to do a read with engine on?
Scooby doo wrote: ........
Ignore that, my learning is bad lol.......…
ned wrote:Idiot, I should read things if your frp is fluctuating then you definitely need a new prv and scv, only buy genuine Ford though.
ned wrote:A wise man said sometime ago your prv and scv need changing
Does the revs fluctuate at idle?
andz327 wrote:Its took until post #47 for you to say that you have a problem and to mention what the problem is lol
Remove pipe from end of prv and see if fuel comes out of the prv
Has the speedo stopped working and miles showing
just lines - - - - - - ?
Sent from my SM-G975F using Tapatalk
