Code reading and learns
Postby Scooby doo » Thu May 06, 2021 6:58 am
Right…
I’m going to bite the bullet and venture out into doing this..
I know it’s been asked before, told many times before..
I’m going to buy a second hand laptop, tho need to know what hardware and software to have on it, ie windows 7 or 10,
Iv seen lots of elm’s too, if someone recommends a good one that’s capable of doing my needs…
Is it a straightforward job to replace the prv and scv or do I need to do learns on these two as well?
Can’t order bits till next Friday on payday, but as the vans undriveable atm and can’t get it to someone and finding it hard to find someone decent to come out to me I’m going to learn to do this myself..
Again, if someone knows how to do these and have a day out in Wycombe then lots of beer tokens are waiting,
Absolutely miss having the girl running, and need to crack on with it next weekend…
Scooby doo
Re: Code reading and learns
Postby andz327 » Thu May 06, 2021 8:46 pm
Elm327 switchable wired from tunnelrat electronics
Forscan works good on my old laptop with the basic windows7
andz327
Postby knobby1 » Fri May 07, 2021 12:12 am
Scooby doo wrote:Right…
ELM 327 here..:
https://tunnelrat-electronics.fwscart.c ... 45457.aspx
Forscan for Windoze here, some time back I had it working on old lappy with Win-XP too..:
https://forscan.org/download.html
Postby Scooby doo » Fri May 07, 2021 5:57 am
Cheers guys, only want to spend around £50 on a laptop and I believe the elm is around £25..shall hunt for a set tonight and hopefully have it here next week..
Does the prv and scv need doing learns on or are they both just fit and go?
Scooby doo
Postby Scooby doo » Sat May 08, 2021 8:16 am
Ordered me a dell laptop with windows 10 and the elm which you guys listed..
Should be here next week, so once here is it all plug and play or does the laptop need to register the elm?
Take this as learning for dummies, but together I’ll get there
Scooby doo
Postby ned » Sat May 08, 2021 8:22 am
Well you will need to download forscan to the computer :wink:
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby Scooby doo » Sat May 08, 2021 9:32 am
ned wrote:Well you will need to download forscan to the computer :wink:
Bit like downloading porn, should be easy enough to do that but Ned me old mucker :lol:
Scooby doo
Postby Scooby doo » Thu May 13, 2021 7:34 pm
Right, laptops here, downloaded forscan the free version, have that all ready, the elm lead is here too..
Going to start this tomorrow morning, is there any correct procedure to do this? Ie start van then run software, or plug in first then start van?
Simple question I know, but I is learning and we all have to learn somewhere, expecting a shopping list tomorrow and will post up my findings with you guys as you guys always know best…one day I’ll be at your level, one day lol
Scooby doo
Postby INTRANSIT » Thu May 13, 2021 11:12 pm
Have you put the drivers for the elm lead onto the laptop?
Mk7 2.2 85ps Fwd 2008 poverty spec
INTRANSIT
Postby gt_addict » Thu May 13, 2021 11:24 pm
INTRANSIT wrote:Have you put the drivers for the elm lead onto the laptop?
Very good point a relatively recent update to windoze removed the old driver for my elm so had to track down a new one and install it. Previously it was auto installed by windoze, but not anymore.
gt_addict
Postby INTRANSIT » Thu May 13, 2021 11:26 pm
INTRANSIT
Postby andz327 » Fri May 14, 2021 7:36 am
INTRANSIT wrote:Just in case you need them
https://tunnelrat-electronics.fwscart.c ... tup-guides
Yeah definitely tunnelrat electronics site will have what's needed....... intransit ......auld Bettsie could do with a little more grunt in her life before she hits 600000mls would you dare help mucker
Sent from my SM-G975F using Tapatalk
andz327
Postby Scooby doo » Fri May 14, 2021 10:44 am
Am I doing summit wrong here…
Right, downloaded winzip as that’s what runs the ch340
Paid and licenced and on desktop tho I still can’t find it on the port drive
Mine don’t even come up with a port list
Followed the instructions and still at square one..
Scooby doo
Postby gt_addict » Fri May 14, 2021 10:48 am
Scooby doo wrote:Am I doing summit wrong here…
Winzip wont directly run the program. That is only to de-compress the files to make them useable. You need to “unzip” the folder (or extract it) to your desktop or suitable location then run it from there, not directly from the zipped folder.
gt_addict
Postby Scooby doo » Fri May 14, 2021 10:55 am
Yeh that’s what it says on tunnelrat, tho, not being technically minded, or was 20 years ago, how do I unzip the file?
Device manager only has the yellow triangle with the elm plugged in, so know I need to unzip it just no idea how..
If you can tell me step by step for a 2 year old I’d be most grateful, this is all new and learning for me, and one day I’ll be able to teach someone else, maybe…lol
Scooby doo
