My injector seals seem to be leaking again after only a few months. Lots of blue smoke (not all the time) and pressurised crank case.
I have bought a "universal" seat cutter set which specifically said it was suitable for a 2.2 transit engine. Only one of the cutters is the same size as the washers (15mm diameter) bit the cutter diameter steps up to 17 or 18mm almost straight away so I'm dubious it will even fit.
If it does fit, how do I go about cutting the seats without getting swarf into the combustion chamber? I don't want to have to take the head off to do it! Or are you only meant to go very gently and take the carbon off and not cut into the metal at all?
Cheers, gill
