I tried finding answers to this, but seems most people have had a wire cut somewhere. Couldn't find any problems with wiring.
History: the car had not been moved for almost 2 months during last summer and when I started it again the abs light stayed on. Before this event it never happened before. So i would suspect something wrong with wiring (like ants eating them?)
Anyhow, i tried to check all wires, nothing wrong what i could find. Also opened all connecters to the sensors and measured the resistance and they all seemed fine, showing exactly the same resistance on all four wheels. Next up, I didn't start the car but put turned the key to on, and measured the other side of the connecters, found out each one receives 4.8V (measured in DC). But this gave me the knowledge because they all measured the same resistance from the connecters to the abs sensors the wiring and the same voltage from the connecters the wiring between the sensors and the abs system should be fine?
I also checked the 2 fuses, one in the engine compartment (20A) and one in the dashboard (5A) and both are okay.
The brake fluid level is topped up, even maybe a bit over max. So should not be that either?
Any suggestions what to do? Where to find the problem?
The car is a Ford transit rwd chassis cab from 2001 with 2.4di 120hp. Can anyone confirm the numbers also?
1.66 -1.68k for the abs sensors?
Car with key in on, 4.8V DC on the other side of the connector?
Brakes are pretty new both back and front. But the sensor is in front only attached to the abs ring and back into drum so probably it can't measure brakes, only speed?
