bambi mk 1 wrote:Lets go back to the start, did you buy it not running if not was it making the noise before the chain let go If the cams are marked in all probability the lobes are twisted and there is where the noise is coming from. It is not recommended to unplug the injectors when running as it can blow the pcm
Brett28 wrote:bambi mk 1 wrote:Lets go back to the start, did you buy it not running if not was it making the noise before the chain let go If the cams are marked in all probability the lobes are twisted and there is where the noise is coming from. It is not recommended to unplug the injectors when running as it can blow the pcm
Any ideas mate ?
bambi mk 1 wrote:Brett28 wrote:bambi mk 1 wrote:Lets go back to the start, did you buy it not running if not was it making the noise before the chain let go If the cams are marked in all probability the lobes are twisted and there is where the noise is coming from. It is not recommended to unplug the injectors when running as it can blow the pcm
Il change the cam and see what happens. Cheers
Any ideas mate ?
You have just read them
