johnski wrote:so how do they get into the van in the 1st place? screwdriver in the door barrel?
i was happy as Larry before i read this thread noo am shiteing myself
gt_addict wrote:They get in with a tibbe lock pick
Trannygrandad wrote:My mark 6 minibus has the obd port re-located, plus, Always. & I stress ALWAYS I fit the steering wheel lock, even if I am only away from the vehicle for a few minutes, it is annoying at first, but once you get used to doing it automatically it no big deal. I also live on a main bus route with chancers ( false plates) slowly driving through, My driveway has a 2ft wall up the side, so I park with the drivers door 2 inches from the wall. that way as the only key hole is on the drivers door, hopefully that will deter them from trying the tibbe key method. As I am disabled I never use the drivers door,. just the remote to open the rear side passenger door that has an automatic step for ease of my access. They could of course break the window to get in but hopefully the hassle will put them off.
gus-lopez wrote:Trannygrandad wrote:My mark 6 minibus has the obd port re-located, plus, Always. & I stress ALWAYS I fit the steering wheel lock, even if I am only away from the vehicle for a few minutes, it is annoying at first, but once you get used to doing it automatically it no big deal. I also live on a main bus route with chancers ( false plates) slowly driving through, My driveway has a 2ft wall up the side, so I park with the drivers door 2 inches from the wall. that way as the only key hole is on the drivers door, hopefully that will deter them from trying the tibbe key method. As I am disabled I never use the drivers door,. just the remote to open the rear side passenger door that has an automatic step for ease of my access. They could of course break the window to get in but hopefully the hassle will put them off.
I have a camper van. I use a steering lock also. I have a obd lock & a pedal lock. When travelling i exit through the rear side door as I use 12mm stainless steel bar through the 'B' pillar in to the door pillar each side, which prevents any type of opening .
The rear doors have shoot bolts internally top & bottom along with external dead locks. The side door has external deadlocks + stainless steel over the outer lock position & always dead locked. It has an alarm + 2 x trackers. I have yet to fit a battery isolation switch.
Mike wrote:MattD wrote:It was probably harder to steal a car back in the 90's!
Yeah that’s why it was so cheap to insure a Sierra Cosworth.
Users browsing this forum: sfnett
