Treebob90 wrote:
How do I check water pump so see if it’s that?
This is how the motor behaves in the overheating protection mode - similar to the limp mode, but the warning light is off.Treebob90 wrote:the van lost power again, still no warning light.
Treebob90 wrote:Will try the fan later
Treebob90 wrote:Also is it possible/happened before that there is debris build up in the radiator that is blocking water leaving it through the exit pipe but if the exit pipe is squeezed it will push the water out of the entry pipe? Like a one way valve sort of effect?
tibsy wrote:Treebob90 wrote:Also is it possible/happened before that there is debris build up in the radiator that is blocking water leaving it through the exit pipe but if the exit pipe is squeezed it will push the water out of the entry pipe? Like a one way valve sort of effect?
Then take Pipes or rad off and reverse flush it!
Treebob90 wrote:Still need to clean rad and check pump but noticed I didn’t put a clip on properly on one pipe when I changed the thermostat (whoops) so took it around the block hoping that would sort it, no luck.
Was driving around fine, heaters kicking out hot air, temp middle of the gauge, started to go up hill and temp shot up. Turned engine of and on and temp dropped back down to middle again.
Am I missing anything obvious?
Cherrs
