Will not turn over, please help I'm out of ideas
Postby kevsonline » Thu Jun 17, 2021 8:28 pm
I have a 2012 2.2 rwd that will not crank.
The starter motor had been burnt out by an enthusiastic driver who would crank the life out of it rather than fix the air leak. I have replaced the starter as well as fitting 2 brand new batteries but no luck.
The immobiliser light goes out when the ignition is turned on. When you go to crank it the battery light goes out while the key is turned and comes back on when you release the key. the only fault codes it has is for No.3 and 4 glow plug circuit fault. will this stop it cranking?
Please Help!
kevsonline
Re: Will not turn over, please help I'm out of ideas
Postby gt_addict » Thu Jun 17, 2021 8:59 pm
So does it crank but wont fire or does it do nothing when you turn the key?
gt_addict
Postby bambi mk 1 » Thu Jun 17, 2021 9:18 pm
Al your problems may stem from a faulty ign switch :wink:
bambi mk 1
Postby kevsonline » Thu Jun 17, 2021 10:27 pm
gt_addict wrote:So does it crank but wont fire or does it do nothing when you turn the key?
It does nothing, lights don't dim, no clicks audible apart from the under seat relay after an attempt.
kevsonline
Postby gt_addict » Thu Jun 17, 2021 11:37 pm
As what bambi has replied with. The ignition switch can cause a variety of issues.
gt_addict
Postby kevsonline » Fri Jun 18, 2021 12:06 am
Ignition switch ordered, even if it doesn't work it will be handy as a spare :D
kevsonline
Postby kevsonline » Sat Jun 19, 2021 8:11 pm
The new ignition switch arrived today and I've just fitted it.
Everything is exactly the same, still not cranking.
Any further ideas?
kevsonline
Users browsing this forum: Google [Bot], Google Adsense [Bot], Majestic-12 [Bot]
