mk7 2013 euro 5 transit 2.2
I am really at wits end and need help on this issue which i think is wiring
I keep getting a low boost p0299 error, and replacing actuator on turbo sorted for a bit but not it is back, and the van has again broken the actuator. I know this sounds like its just sticky vanes but my garage says they seem fine.
What worries me is that there is a high pitched whining / buzzing noise when the ignition is one (and when van is running too). It stops if I unplug BOTH the EGR and Turbo actuator, but if one is plugged in it buzzes. The actuator is sort of trying to constantly return but can't. But why would it also buzz when unplugged but EGR is plugged in?
Recently too I've had error codes of instrument panel connection loss. AND a few weeks ago i reconnected a broken wire on the dpf because i was getting a dpf error, and a few miles later the van stalled, and said crank shaft sensor error, and immobiliser error.
It;s like the electrics are knackered or shorting somewhere?
Where would I start looking?
The van has had EGR and DPF delete and retune by vantuner
any help of where to start would be great!
