Hi,
I bought a 20 years old transit camper and it has a lot of problem-issues:-)
At first i will fix the break problem:
Error Description:
- if i start ignition break light goes on ( 1 or 2 sec) and out ( i think thats normal)
- if start engine light is still of ( also normal)
- if i ise the break pedal ( or only push the switch there ) break light goes on
- it is on until i stopp the engine
What have i done:
- i checked break flluid = ok
- i checked break pads = ok ( but there is anyway no pad wire )
- i checked break back light ground connection = ok
- no oBd2 alarms in this topic
What can it be...
I think there is no handbrak switch, can it be the fluid switch?
Is it possible that the drum break has to Do with this ?
Maybe someone can help.
Regards daniel
