by Andy123456 » Mon Jul 19, 2021 2:14 pm
Hello
Just managed to join this forum after finding loads of useful info from here and being unfortunate enough to own a mk6. Thanks for any help offered here and hello to all.
My van cut out, almost like it died instantly 2 weeks ago, i had the fault codes read by ford ids and it was showing various codes relating to the dreaded pump. As i was told its a high percent of the time the edc that fails so i sent this away to ecu testing and 325quid later they said there was a fault on the circuit board, repaired it and sent it back to me. I refitted, used heatshrink to rejoin and filled and fitted a new fuel filter. I used a priming bulb with injectors cracked open to bleed as much air as i could, tried a squirt of easystart and the van still wont start 2 weeks later. I have checked all earth points, fuses, relays, looked for chaffed wires over the starter and at the loom, checked the timing and still no joy. Ive just spent 12 months welding a huge amount of rust to get 12 months mot and got 4 days use before the van died. Its done 80k miles so not high really. Its driving me mad, i am returning only one fault code now with forscan and it is p1564 module pcm fip requesting reduced fuelling. I have no other codes anymore. Prior to only having this code before repair i had fip fault code, egr fault code, pcm code, etc but after replacing with a good battery, fitting repaired edc i am just left with the p1564.
Any ideas of where to look next, what could cause this code,
Im just about ready to scrap it as i dony have enough knowledge to rectify this fault but after having so much welding, new arches inner and outer, sills, steps, chassis repairs etc, too much has been done to give up.
Is there anyone knowledgable willing to have a look at it without it costing me a fortune?
