dumper wrote:When you fitted the discs/ pads/ handbrake cable before you pressed the brake pedal and pumped the piston out for the first time to adjust the pads to the disc did yo make sure the handbrake lever on the calliper was all the way off .
dumper wrote:A 2007 is not a mk4 it’s a mk7 they stopped making mk4s in the 20th century unless you are not uk based
steelemonkey wrote:Mods, could this thread be put into the section for Mk 4 please, and have the title put back to Mk 4 handbrake problems. Cheers.
steelemonkey wrote:So far I have replaced the master cylinder, all four callipers, all four flexible hoses, both rear handbrake cables and all brake pads. Still no handbrake on the nearside.
I am stumped!
Users browsing this forum: Google [Bot], Google Adsense [Bot], Majestic-12 [Bot]
