Anyone able to get me an ABS wiring diagram for a Mk7 2.4?
After a headgasket change earlier in the year, I found the expansion tank had overflowed and as a result, managed to soak to the ABS connector into the ABS control module. I’ve changed the control module and it’s now connected and can do a ABS service bleed etc , however my ESP/ABS lights are on and non functional.
I’ve cleaned up as much as I can on the plug, but guess there’s still a couple of pins being problematic, but with the 20 wires in the plug it’s a bit difficult to guess. Would imagine the circuit for the brake sensor isn’t at right voltages…
Any help much appreciated, can’t find any references to the DTC online
Dtc: C1A99:00-2B brake pressure sensor
