BCM Click / Intermittent Electcial Gremlins
Postby trannyman99 » Sun Sep 19, 2021 1:53 pm
Hi all, '06 2.2L diesel van, FWD.
Been having a few intemrittent electrical gremlins, done a bit of a search for BCM issues here but havent found any exactly the same issues as mine. Van is good condition, well maintained, no rust, lots of new parts, 2 new batteries (leisure battery installed) runs, drives, stops great.
Intermittent issues;
- 1 in 10 times can be hard to start, I can definitely hear a clicking from the BCM sometimes.
- Sometimes random doors dont lock / open
- Sometimes when van starts up, pushing the throttle does nothing for 5 seconds or so, then is fine.
- Forscan shows a range of BCM codes;
U300A
B1C83
B1097
U0151
U0121
B10AD
B10D7
Ive checked the earth which seems in good nick, will run a new earth cable to the enigne just to be sure.
Anyone have any ideas? Bad BCM? What would cause the internal "click" - im guessing that is the root cause...
Thanks!
trannyman99
Re: BCM Click / Intermittent Electcial Gremlins
Postby trannyman99 » Wed Sep 22, 2021 5:55 pm
Bump. Anyone? tia
trannyman99
Postby andz327 » Thu Sep 23, 2021 12:11 am
Easiest and cheapest to try is new ignition switch if you haven't tried one they're about £22 from RATES FORD dealer on ebay
Sent from my SM-G975F using Tapatalk
andz327
Postby trannyman99 » Tue Sep 28, 2021 2:29 pm
No, not the ignition switch.
I reckon that the clicking of the BCM is the giveaway when turning the ley (sometimes), and after researching further it appears there are 2 relays in the centre of the BCM circuit board - so im pretty confident its one of those on board relays failing.
So im gonna replace it with an ebay one.
So I believe the procedure is;
1. using Forscan with full license backup the existing BCM, restore it to the replacement one OR copy the master BCM code from the master dash copy...?
2. do a PATS key re-program also using Forscan?
I wont need any other software will I?
tia
trannyman99
cron
