I have a 2011 diesel Transit with 129,000 on the clock. It's the 2.2 engine, 115 T300S ex. police van that I've converted into a camper. About two years ago it started to develop a problem starting once the engine had warmed up e.g. a twenty-minute drive to the shops could mean difficulty in starting once I'd completed my shop. The engine turns over, but then peters out before it starts. If I leave it for an hour or so, it will start with no problem and it's started from cold (e.g. minus 7 degrees) with no problems.
In recent weeks, I've had the starter switch and inlet metering valve replaced. The garage reports that the batteries and starter motor are fine and nothing untoward is showing up on their diagnostic equipment.
I telephoned a diesel injectors specialist this morning and they said they'd never heard of injectors causing this issue.
Can anyone point me in the right direction?
Cheers.
