Dash clock and Trip Counter not saved after ignition off
Postby northernboy » Mon Sep 20, 2021 4:58 pm
I turn on ignition, all seems OK, but clock is always 00:00 and trip counter is 0 these then start working normally but as soon as I stop and turn off the ignition, these see to loose power and reset
Any ideas ?
northernboy
Re: Dash clock and Trip Counter not saved after ignition off
Postby northernboy » Sun Oct 31, 2021 9:12 pm
I solved this problem - was simply fuse 210 in the dash fuse board was missing :)
northernboy
Postby Altransit » Sun Oct 31, 2021 9:22 pm
Good result then 8) Thanks for posting back :)
Postby DG-Unit » Mon Nov 01, 2021 11:32 am
You worked it out a lot quicker than me :lol:
viewtopic.php?f=5&t=210509
2004 Transit SWB 85 T260
DG-Unit
