Hi everybody,
Mk6 2.4rwd 2003/4. High spec loom.
i think i have a broken wire that goes to the abs module, i have the abs and handbrake warning lights come on, the codes showed the module was faulty.
I replaced the module and the lights went out and no code. Everything was fine for about 200 miles then the lights came back on and the same code came up. Saying module problem.
I think i have a broken, corroded wire somewhere but where do i look, im tempted to strip all the insulation of the wiring and try to track it down but before i do i wanted to see if anyone had found a place that seems to be problematic.
Any help would be appreciated
Sent from my SM-N981B using Tapatalk
