Driver side striker plate
Postby Jp71 » Sat Sep 25, 2021 11:37 am
Looks like there are some cracks in the paintwork and a bit of rust starting to form, is this a major or can it be fixed relatively easily? Will post some photos in the morning. Hoping it’s not so bad that you have to access from behind as it’s built out and that would a right pain the arse to take off that plastic cover the seatbelt mechanism lives behind.
All advice welcomed, cheers
2007 2.4t dci
140T350
Jp71
Re: Driver side striker plate
Postby knobby1 » Sat Sep 25, 2021 9:21 pm
Jp71 wrote:Looks like there are some cracks in the paintwork and a bit of rust starting to form, is this a major or can it be fixed relatively easily? Will post some photos in the morning. Hoping it’s not so bad that you have to access from behind as it’s built out and that would a right pain the arse to take off that plastic cover the seatbelt mechanism lives behind.
Some rust spots are just the tip of the iceberg, best to get it sorted.
Postby Jp71 » Sat Sep 25, 2021 9:24 pm
Thanks mate. I figured this was the case. Is it likely the plastic housing behind is likely to need to come off or too hard to say without seeing the situation (as I’m expecting is the case). Trying to mentally prepare myself if I have to dismantle the camper
2007 2.4t dci
140T350
Jp71
Postby Airthies » Sun Sep 26, 2021 8:52 am
Done a couple now that are cracked round the striker.
I've just welded up from outside, it is a pain to get it ground back though with the profile of the panel if your wanting a neat finish
Sent from my Armor 8 Pro using Tapatalk
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Jp71 » Sun Sep 26, 2021 8:55 am
Airthies wrote:Done a couple now that are cracked round the striker.
Nice, thanks. Sounds like a job for the panel beater. Cheers
2007 2.4t dci
140T350
Jp71
