Gday,
Have had a belt squealing issue for a couple months now and each time I make some sort of change it persists. Currently the squeak only happens above 2000rpm and gets louder as revs increase beyond that. Its a 2007 2.4L rwd.
Initially I started with the obvious fixes: new belt, new tensioner, new idler. No luck. It seemed more investigation was needed. Next thing was the fan hub clutch as it had far too much play (in hindsight this was unlikely to be my squealing problem but was glad to replace it regardless). Then the cooling fan pulley was next, I noticed the belt was running towards the front edge of the pulley instead of the back. Still no luck. At this point i talked to an uncle who works at ford, he said that the belt brand may have something to do with it. I decided to spend the extra cash and put on a genuine ford belt instead of the dayco one I had chucked on earlier. This immediately fixed the problem but the squeak came back (a different sound this time) after not even a week.
At this point now I'm assuming its a bearing in one of the pumps, the crankshaft/harmonic balancer being worn or something else entirely, but am not sure what the best process is for diagnosing its source. I'm hoping one of you blokes here have had or heard of a similar experience. Cheers for ya help in advance, this squeal has been doing my head in.
- One very lost bloke from down under
