Engine Stuttering this morning.
Postby M4CKK » Wed Oct 13, 2021 8:39 am
Mk7 2.4 RWD.
98k miles minibus.
Inspected every 6 weeks.
Half tank diesel.
Running perfect until this morning when, after starting, it stuttered for about 3minutes.
Seems ok now.. but what may have caused that?
Sent from my ONEPLUS A5010 using Tapatalk
GasSafe Registered Installer - Chimneys Swept - Cowls Fitted - Chimney Pots Fitted - Wood Burner Stoves Installed - On-Site Welding
M4CKK
Re: Engine Stuttering this morning.
Postby knobby1 » Wed Oct 13, 2021 8:06 pm
Have you had the codes read..??
I'll take a guess at the EGR valve.
Postby M4CKK » Wed Oct 13, 2021 8:36 pm
Thanks Lord.
Having it read in the morning.
It has been fine all day 45miles.
Just faulty this morning.
M4CKK
Postby M4CKK » Wed Oct 13, 2021 8:37 pm
What sort of job is it?
M4CKK
Postby knobby1 » Wed Oct 13, 2021 9:44 pm
M4CKK wrote:What sort of job is it?
RWD's are a pain in the ar$e....often the bolts are rusted and can strip the heads when trying to remove....two of the bolts are easier to get at from underneath.
But make sure it's faulty before takling it....bit silly replacing it if it's working fine.
Postby M4CKK » Thu Oct 14, 2021 12:45 pm
Code ReadingImage
M4CKK
Postby M4CKK » Fri Oct 15, 2021 7:47 am
Better pic.
No dash warning lights on either.
Sent from my CamperVan
M4CKK
Postby Altransit » Fri Oct 15, 2021 10:02 am
Postby M4CKK » Fri Oct 22, 2021 6:05 pm
Well, got a new egr installed, excellent.
Had new oil and filters done too.
I live and work out of the campervan so like to keep on top of things.
Anyway, asked them to remove the 100kph limiter... they tried.
Plug in PC said it had done it.. but no, still on 100kph.
Is it a main dealer job?
Or - anyone on here able to do it?
I'm always up and down M1, Junc22 to Junc38.
Cheers all
M4CKK
Postby knobby1 » Fri Oct 22, 2021 9:35 pm
M4CKK wrote:Well, got a new egr installed, excellent.
Cheers all
I understand minibesses are hardwired to max speed of 100kmh (~60mph). I believe they can be "mapped out"....Martyn (Vantuner) would know for sure.
Postby M4CKK » Fri Oct 22, 2021 9:51 pm
Cheers all
M4CKK
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot]
