Hi guys,
Vans been running fine for ages but just had some problems start with the clutch. It will go into gear fine when the engine is off, but with it running I have to press the clutch a couple of times to be able to put it in gear. It is a similar story when taking it out of gear. Sometimes it comes out first time and other times it needs to be pressed a few times before the clutch engages and I can take it out of gear. I then have to press it a few times to put it into a new gear. I’ve checked for leaking fluid and can’t see any. And the pedal hasn’t changed in firmness, it still feel firm and not spongy.
Anyone have ideas as to what it could be? It’s a Mk6 2001 lwb rwd 2.4l.
Thanks for your help,
Tom
