Hi, done a bit of searching but wonder if someone can help please. Sorry very new to Transits and programming them.
We have a UK MK7 Transit 2008, 2.2L Duratorq TDCi (140PS), FWD.
The BCM was giving all sorts of weird errors, clicking, cutting out, not starting etc. so have bought a second hand one to replace it.
Using Forscan with ext. licence, we were unable to backup / take a copy of the original BCM data. Just kept erroring.
Ive read dozens of posts about getting the original AS-Built data to program the new BCM with, and entered the VIN on this site. https://www.motorcraftservice.com/AsBuilt
However, the file which gets returned seems to be too small, only 1kb in size, so something isnt right.
Weve plugged the new BCM in, reset it using Forscan, and PATS coded the keys. The van runs ok, but there are lots of irritating issues - which I *think* may be due to the default BCM config being American perhaps?
- Daytime running lights are on, cant be be turned off
- Alarm doesnt work properly
- One side door wont open
- Rear demister cant be turned on
...and a few others - all settings for which seem to be missing from the Forscan BCM programming / engineer config settings.
So I wonder if someone could please point me in the right direction - how do I get the correct default BCM config so I can change the settings - is there a UK AS-Built I need to apply?
Thanks in advance.
