phatboy wrote:Hi thanks for the reply yes all injectors went back in the same location
when I first plugged in I go this little list lol
And after clearing with forscan I got
P037d
B1083
B1094
B1932
Phatboy
phatboy wrote:Would the engine still turn over ok if the chain jumped
phatboy wrote:Checked with forscan on the cmp and ckp sync read pid data and it should no when off and yes when cranking is that what it should be sorry new to forscan.
phatboy wrote:Shows yes when cranking and no when just ignition on so guessing that all in sync checked the glow plugs as well 2 showing no voltage 1 is 2 volts and 2 and 11volts
phatboy wrote:So replaced both batteries now has nice strong crank I checked the fuel filter and that is ok I managed to get it to run for about 20 seconds with easy start but it wouldn’t idle and it’s sounded awful really loud knocking wondering if the injectors are duds
Users browsing this forum: Google [Bot], Google Adsense [Bot], Majestic-12 [Bot]
