Mk6 2.0 TDCI 2 stroke
Postby BarnabyB » Mon Oct 25, 2021 12:55 pm
So I've had a good trawl around the forums regarding using 2stroke in a 2.0 tdci and found plenty of glowing reports from users but none mentioning using it in this engine. I only ask because I know the 2.0 tdci is a sensitive soul and I'm wondering if anyone has tried 2stroke in theirs and how it faired?
Thanks in advance and thanks for the forums and all the input. Have saved myself a fair few pennys being able to do the work myself!
Mk6 2.0 TDCi 2006
BarnabyB
Re: Mk6 2.0 TDCI 2 stroke
Postby metalworker0 » Mon Oct 25, 2021 7:35 pm
I've read about it ..it does not go in the engine - you add it to the diesel - supposed to make the diesel injector pump last longer.
Postby BarnabyB » Mon Oct 25, 2021 8:20 pm
Sorry bad wording there...yeah I've read 200-300ml per tank can work well, nothing much about using it in 2.0 tdci's though.
Mk6 2.0 TDCi 2006
BarnabyB
Postby BarnabyB » Tue Oct 26, 2021 4:05 pm
Also any ideas which would be best out of mineral, semi or full synthetic? Thanking you in advance :D
Mk6 2.0 TDCi 2006
BarnabyB
Postby metalworker0 » Tue Oct 26, 2021 6:52 pm
According to people ..its got to be mineral, as synthetic does not mix properly with the diesel and separates out.
all the info is on YouTube ..some by red neck types of people some by clever ones.
Postby ned » Tue Oct 26, 2021 7:08 pm
When I had my mk666 tdci I was very dubious about putting anything other then diesel through that delicate fuel system, those Delphi pumps and injectors are a law onto themselves and don’t need any help in becoming fubar.
viewtopic.php?f=2&t=193839&p=1650448&hilit=2+stroke+oil#p1650448
viewtopic.php?f=4&t=175230&hilit=2+stroke+fuel+additive#p1490501
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby BarnabyB » Thu Oct 28, 2021 1:44 pm
Yeah ok, thanks very much for the advice. Will probably avoid any 2 stroke then. What about injector cleaner though?
Mk6 2.0 TDCi 2006
BarnabyB
Postby ned » Thu Oct 28, 2021 7:00 pm
Are you having problems?
I periodically used to remove my injectors one at a time and clean them up with brake cleaner then put them back in, mainly to remove the carbon build up, just don’t take them apart, I did and it opened a whole world of pain :lol: :lol:
ned
Postby BarnabyB » Wed Nov 03, 2021 3:56 pm
I am having a little trouble aye. Uphill in 4th or 5th sometimes gets limp mode going. Ignition off and on cancels it and all is back to normal. Had the codes checked and get an injector fault. I hear its worth checking the wiring behind the starter motor for ware....is that a good place to start? Will try giving em a wee clean too thanks.
Mk6 2.0 TDCi 2006
BarnabyB
Postby ned » Wed Nov 03, 2021 7:06 pm
Aye the wiring around the starter rubs through, I rerouted the wiring on my old mk6 tdci, I have some injectors here from my old van, 4 x remans about 2 years old and 4 used from a running van that I can sell you if you need some injectors
Just noticed yours is an 06 so don’t know if these injectors are compatible as the nozzles might be the shorter ones on your van.
ned
Postby Jim Archer » Fri Nov 05, 2021 1:31 pm
Given that most premix 2 stroke engines are run at 60:1 minimum oil ratio (down to 100:1) for low stressed stuff, 300cc in 75L isn't adding a lot of lube to the diesel.
That said, my old Smiley TD conversion seemed to like the few litres left over 40:1 left over race bike fuel chucked in the tank - Castor based, so you can't store it once mixed in Unleaded petrols :D
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Postby Altransit » Mon Nov 08, 2021 3:22 pm
My Mk5 and Mk6 Tddi both used to love it, I haven't had the nerve to try it in the TDCi Mk7 :shock:
Postby Jim Archer » Tue Nov 09, 2021 3:51 pm
Possibly not the best thing, but have chucked some left over 30:1 Avgas/Castrol A747 in the Mk7. Was just a few litres in a nigh full tank of diesel. Can't say as I noticed any affects at tge time, and all still happy 15K miles later.
Jim
Jim Archer
