ned wrote:That’s lucky that only 2 are wrong, I think that’s what you press, I’m not too clued up on these new fangled mk7’s yet, it’s been a few years since I coded injectors on my old mk6.
knobby1 wrote:ned wrote:That’s lucky that only 2 are wrong, I think that’s what you press, I’m not too clued up on these new fangled mk7’s yet, it’s been a few years since I coded injectors on my old mk6.
Yep, Forscan doesn't use the "firing order"...it just uses #1,2,3,4 front to rear on a RWD and left to right as you look at the engine on a FWD.....pretty simple to do.... and I still think Forscan is a terific resource considering it's free to download.
Once the injectors are coded, a set of learns is required to set them up nicely.
Rollingbob wrote:knobby1 wrote:ned wrote:That’s lucky that only 2 are wrong, I think that’s what you press, I’m not too clued up on these new fangled mk7’s yet, it’s been a few years since I coded injectors on my old mk6.
Thanks I did it and working after 10 mins/up one hill but need to run her for longer to be sure of fix and haven't done the learning.
Rollingbob wrote:Haven't dome the learning yet but same problem as before - almost complete loss of power after 10 miles. Should be ok to get back when engine cools back down.
Not the MAF as just tried new one to no avail.
Rollingbob wrote:Well i just made it back home lol. Revs were struggling with peddle right down (4000 then bouncing 2000) and some black smoke from exhaust.
There's also still some oil leaking from somewhere
Rollingbob wrote:Well i was just testing (had to floor it get emissions below 0.30 or whatever it was to pass recent MOT).
No haven't done EGR Valve, sounds like a plan
PCM fault codes are:
P2125:36-28 - Throttle/Pedal Position Sensor/Switch E Circuit
P037D:29-2F - Glow Plug Sense Circuit
P1409:77-28 - EGR Vacuum Regulator Solenoid Circuit
P068A:00-28 - ECM/PCM Power Relay De-Energized - Too Early
