Hi guys, I have problem with electricity, most of the time some electric systems do not work, it is:
Turn indicators, heating fan, windows, manual clima, reverse gear light. Heating always heat, even though it is set on cold level.
Problems started with some strange noise in the area on drivers left hand - somewhere under steering wheel.
Sometimes it works, sometimes not. It is betting worse as the time goes by - few months ago it stopped working only for few minutes, then it was like 50:50, sometimes it was fixed when I switched the engine off and on, but now it is 90% non functional.
I checked fuses (and applied contact spray) to every contact on the flue box on the right part of a dashboard, but no effect.
Could you give me some advice where to start? What does these system have in common?
My car is Transit V184/V185, 2.0 TDCi (125), year 2006
Thanks!
