scas wrote:the tddi injectors rarely fail, with the engine running, loosen the pipe to the injector on that cylinder, see if the noise stops- its probably the timing solenoid on the pump-if i had to guess
Louey wrote:I ran the engine and loosened each pipe on the injectors, one at a time. Each time I think I had a difference in engine revs. Went for a drive and it still sounds as rough. Took a video to see if this helps getting a diagnosis.
https://youtu.be/8CKwnT9Ie3s
Now, would swapping out the injectors solve the problem? The mechanic reckons it would , but also said putting a new chain on would. The codes still point to the pump and solenoid, which were brand new in April.
knobby1 wrote:Louey wrote:I ran the engine and loosened each pipe on the injectors, one at a time. Each time I think I had a difference in engine revs. Went for a drive and it still sounds as rough. Took a video to see if this helps getting a diagnosis.
What actual codes are you getting..??
Louey wrote: The codes still point to the pump and solenoid, which were brand new in April.
knobby1 wrote:Louey wrote: The codes still point to the pump and solenoid, which were brand new in April.
richardstubbs wrote:Are you sure you're timing it right? This sounds like an over-advanced pump to me - it's very easy to get the timing pin down the side of the cast boss with the hole in it, rather than in the hole. Took me a couple of goes on the FWD because you can't really see the hole. It's much easier with the full timing cover off. Also, are you sure you've got the engine in the right place to start with? That's a bit awkward too, and again much easier with the cover off because you can get the crank in nearly the right place first.
P0149 means that the timing is out. Can be the solenoid, but can just be that the timing is out. There is an engine position sensor in the pump, and if disagrees too much with the crankshaft sensor it'll throw this code.
P1564 means that the fuel pump has reduced power to avoid engine damage. Neither are anything to do with the injectors at all.
