metalworker0 wrote:This is me preparing myself watching youtube videos so i don't come unstuck and pay ££££££out in the future . the video is slow but there is a lot to learn from it
Take the things out ..and look on it as servicing!
https://www.youtube.com/watch?v=guYFnOMlR_k
buy a used set and have them serviced as in the video, keep them safe ready to swap out when there is trouble
can anyone see anything wrong with my logic ?
scas wrote:The steel washers are usually welded to the injector cos of time and heat, the seals are just metal/rubber things and reuse them all.
Louey wrote:scas wrote:The steel washers are usually welded to the injector cos of time and heat, the seals are just metal/rubber things and reuse them all.
So do I get copper or steel washers?
Louey wrote:Took two injectors out, dismantled them and cleaned them up. Both had good spray pattern from their nozzles.
I removed the sleeve off injector #1 and I broke the little circlip that helps it stay in place, so I couldn't refit injector #1. Can you get the circlip as a spare part anywhere? I've had a look and can only find replacement nozzles so far. Not too desperate as I should be getting an injector in the post tomorrow.
Louey wrote:I was trying to sort a diagnosis beforehand.
