Anothertransit12 wrote:Hello people. My 2011 2.4 devoloped a major fuel leak whilst driving and came to a stop. It appears to be leaking from the top head of the fuel pump. Did any of you take off the pump head to repair seals or is this a no go area best left to diesel injection specialists? If you did what bits did you have to remove to gain access
Anothertransit12 wrote:I might run it out and reseal it as it is not a big job but it seems to be very wet on top of the cast steel pump head (which is higher up ) after cranking. It looks like it is just running down the pump and dripping at the temp sensor .Will update you when i get time to look at it. Thanks
knobby1 wrote:Anothertransit12 wrote:I might run it out and reseal it as it is not a big job but it seems to be very wet on top of the cast steel pump head (which is higher up ) after cranking. It looks like it is just running down the pump and dripping at the temp sensor .Will update you when i get time to look at it. Thanks
If it is coming from above the switch,you may need to get in contact with a diesel specialist as the cover O-rings etc aren't sold separately by Ford unless they sell a repair kit..
Users browsing this forum: Altransit
