Simpulsar wrote:Hi everyone, I've bought a 54 plate transit tipper and it's just started playing up.
It's been totally fine but It hasn't been used for a while, everytime I start it up it starts and ticks over great, as soon as it gets warm it starts to misfire and smoke and its undrivable.
I've changed egr
Changed injectors
New injector pump
And it's still the same, it's like a white/grey smoke. It's not losing any coolant or overheating
Anyone got any ideas to help me out
Simpulsar wrote:Sorry. It's a 2.4 tddi and a 90
No havent had the codes read. My machine wont communicate with it for some reason
Also dont have any lights on the dash, should it still pick up something
Simpulsar wrote:Right guys, I've had some time on the transit today and it's bad news unless I'm thinking wrong
I checked the oil today and it seemed to be overfilled, cracked the sump plug to running water so there is water getting in my sump
I'd say it's knackered and new engine job
Anyone want to shed some light on the situation, don't want to spend money on headgasket if I'm gonna get the same probelm if block is cracked ect
Also another problem I'm having is I have no fuel gauge, temp gauge, rev counter,speedo, clock or millage showing/working. I do have power there as I have ignition,oil,abs lights working
Simpulsar wrote:Well it's good news for thel clocks, stopped them out and sprayed them with wd40 electrical contact cleaner and they are all working.
Can't get the van running after changing the fuel filter to see if I have solved the smoking
Will update when I get abit further
Simpulsar wrote:Update *****
Van is now sorted, changed fuel pump and had it recoded and it's all been fine for the last few days
