2.4 RWD Diff (ex RAC)
Postby Chris.Hen.81 » Sun Jan 16, 2022 3:54 pm
Hi All,
I currently have a 09 mk7 2.4 RWD transit (ex RAC).
I knew it has the 5.11 ratio which everybody knows the issues I am having ie, 2700 rpm for 60 mph.
I am looking at changing it as won't be towing caravan as much more daily driving and reading through other posts a 4.27 or 3.73 is probably the way to go with. It has been remapped.
A couple of questions and if anybody able to help that would be great.
1. I knew it needs to be a mk7 5 stud?
2. Does it have to be same engine size ie 2.4 or ok for 2.2?
3. I guess it needs to be 5 speed to match what I currently have or does it not matter if 6 speed?
4. What ratio is everybody else running?
Thanks again in advance.
Chris.Hen.81
Re: 2.4 RWD Diff (ex RAC)
Postby knobby1 » Sun Jan 16, 2022 8:17 pm
Rear axle for the 2.2 and 2.4 RWD Mk7's are the same.
5 or 6 speed makes no difference. 1st gear in the 6 speed is only good for climbing trees.
If you're not towing or carrying heavy loads, the 3.73 would be ideal. You can get 3.58 and 3.31 as well.
I use a 4.27 as I often carry a decent load.
Postby dirtydog » Sun Jan 16, 2022 10:56 pm
I’ve got a 3:73 axle in my ex rac mk7, I don’t carry particularly heavy loads and I rarely tow anything so it’s perfect for me.
My mk7 camper however has the 5:11 diff and it’s horrendous at motorway speeds, bad enough that I’ve got a 3:73 axle to fit on it at some point
dirtydog
Postby Chris.Hen.81 » Mon Jan 17, 2022 8:41 am
Yeah I’m thinking 3.73
I’ll only probably be towing a caravan 2/3 times during the year and if it’s not going to struggle as don’t really like gear box tennis when going on inclines.
Thanks for the advice.
Chris.Hen.81
Postby knobby1 » Mon Jan 17, 2022 7:56 pm
Chris.Hen.81 wrote:Yeah I’m thinking 3.73
Depends on which engine you have, 100, 115 or 140.....if 140 you can go with pretty much any ratio......if 100 or 115 you may struggle using a 3.73 or lower with a load on.
Postby Chris.Hen.81 » Tue Jan 18, 2022 7:15 pm
I have FORD TRANSIT 330 SWB 100 with remap.
So a 4.27 would suit better? I don't want to risk struggling with caravan or car trailer on.
If anybody knows the best place to get 1 from then all information gratefully received :D
Chris.Hen.81
Postby knobby1 » Tue Jan 18, 2022 8:42 pm
Chris.Hen.81 wrote:I have FORD TRANSIT 330 SWB 100 with remap.
If you need to tow or carry a load....the 4.27 is a good "all-rounder" ratio, tows well and not too bad on the motorway. Can't help with where to get one as I'm in Australia.
