is it 36mm?
got a broken spring and the pinch bolt on the hub that holds the shock is rounded so have to remove the whole fecking thing including the hub
so 36mm?
ned wrote:you could pop the ball joint out of the hub/knuckle instead.
ned wrote:Sds drill will get the bugger out
