by Noctule » Fri Jan 21, 2022 2:35 pm
Don't forget that headlights are designed to use a particular type of bulb. An LED bulb can't exactly reproduce the light pattern of a filament bulb. Vehicles with LED bulbs from the factory will have appropriate lenses too.
Currently it is illegal to fit LED (and HID) bulbs in a headlight which should have a filament bulb in it.
And yes, LED bulbs can break.
The Motorhome Fun forum will tell you the same.
If you have a problem with the quality of your headlights then fit new headlights and/or quality branded bulbs as mentioned above.
Mat
2000 Mk5 HiCube self-build camper
- 2.5tdi 4EA with EPIC-to-Bosch conversion
- DRW with 16" rims
- Mondeo instrument cluster
- Lunar Meteorite interior
2006 Mk7 115t350 van (cheap tax tramp)
Previously...
Mk5 100 swb Custom
Mk5 190 lwb x3
