Yes you can but they are smd's, soldered to the circuit board.PWRR-TRANSIT wrote:Hi guys.
Can you replace the bulbs in the cluster individually? If i take the cluster out will i be able to access each bulb and replace them?
Thanks.
Gappy1uk wrote:Yes you can but they are smd's, soldered to the circuit board.PWRR-TRANSIT wrote:Hi guys.
Thanks.
Sent from my SM-G970F using Tapatalk
Just abit of patience. The cluster needs to be dismantled and needles taken off but it is doable.PWRR-TRANSIT wrote:Gappy1uk wrote:Yes you can but they are smd's, soldered to the circuit board.PWRR-TRANSIT wrote:Hi guys.
Thanks.
Is it easy enough to pull one out and re-solder one back in?
Each led has to go a particular way round or it won't work, can cause other issues alsoIsupchap wrote:So I’ve just started to do this (change the green LEDS to blue ones)
Got one side done and put them back together to check I was dining things right!
And I’ve lost my green square readings
Have I put it back together wrong or have I ballsed it up and now need a new set of clocks?
Any help will be appreciated
andz327 wrote:There's actually 2 wires you can join to put light out, I can't remember what ones but LOOT may know off hand if you give him a shout
Sent from my SM-G975F using Tapatalk
This is what I didPWRR-TRANSIT wrote:andz327 wrote:There's actually 2 wires you can join to put light out, I can't remember what ones but LOOT may know off hand if you give him a shout
You mean like making an electrical short? That can't be good surely?
PWRR
Gappy1uk wrote:This is what I didPWRR-TRANSIT wrote:andz327 wrote:There's actually 2 wires you can join to put light out, I can't remember what ones but LOOT may know off hand if you give him a shout
PWRR
PWRR
